Discussion topic: I can't login to my sky WiFi it says invalid password
This message was authored by Beniamin1 This message was authored by: Beniamin1
Re: I can't login to my sky WiFi it says invalid password
@Beniamin1 Carefully check the password printed on the hub as it is quite easy to misread a letter for a number or vice versa. If you are still stuck tell your device to dorget the connection, reboot it and try again as some devices can have issues with previous wifi passwords not clearing properly from memory meaning they can't accept the new one.
