30 Oct 2022 02:13 PM
I am not able to connect to some websites when using wifi but I can on my mobile hotspot. How can I rectify this?
30 Oct 2022 02:15 PM
Posted by a Superuser, not a Sky employee. Find out more@Suzanne8121What setting is broadband shield set at. By default it is set at PG-13. This can be found in my account.
30 Oct 2022 02:16 PM
It may be sky broadband shield.
What sites can't you access?
30 Oct 2022 10:07 PM
I had the same problem this week. I couldn't access a website, though I could if I used my phones mobile data + hotspot. I also could using a vpn, so I knew it had nothing to do with my browser.
I read that this can be caused by the websites company blocking an IP range which includes the one your public IP the Sky router has been assigned. The way to remidy this is to turn the router off, long enough for it's IP address to be 'forgotten'. I had mine turned off overnight and that caused it to get a different public IP and, bingo, I could access the website when on WiFi.
Hope this helps
14 Mar 2023 06:02 PM
I had the same problem using my Safari on my Ipad IOS 16.
I disabled Broadband Shield and the sites loaded fine.
Enabled the Broadband Shield and the problem returned.
Suggested fix if your using Safari browser for Apple IOS.
a. Go to Settings
b. Scroll down and click Safari
c. Scroll down and check if Hide IP address is enable
d. Click on this option / setting and turn this setting to OFf.
e, Clear browsing history under Safari
f. Start Safari
Check if the sites are loading
SKY broadband Shield is not compatible with this particular setting as some sites require your IP address and location to tracking your browser habbits.
Hope this helps.
06 Jan 2024 02:13 PM
I just fixed this issue on an iMac by limiting my IP address tracking in the Wi-Fi settings. I've turned the setting back on and I can still access the website. This was after resetting the router with the help of Sky's tech team!
11 Feb 2024 11:42 PM
I had the exact same problem until I tried going behind a VPN. That solved the problem but it does slow down the download speed
