Discussion topic: I am having trouble with Netflix. My app is saying my signal/WiFi is fine. But Netflix won't load at
This message was authored by: Charlottebmlloo
Message posted on 17 May 2024 08:56 PM
I was watching Netflix and then it just stopped. And gave an error can't connect. My app says WiFi/signal is fine. Had anyone else had the similar issue or knows a fix?
Find out more
Message posted on 18 May 2024 08:24 AM
Re: I am having trouble with Netflix. My app is saying my signal/WiFi is fine. But Netflix won't loa
@Charlottebmlloo rebooting the device that you were using often clears issues. Netflix is a pretty robust service but while you can have enough bandwidth if the Wifi signal is suffering from interference if enough data packets get lost the stream stops so if it happens again tryvrestarting your Sky hub as that will cause it tonfind the least congested channel for wifi.
