03 May 2024 12:20 PM
My Sky Broadband keeps *intermittently* failing. It works perfectly for a few hours and then fails for a few minutes. I've tried the usual unplug, turn it off and on again - and it still does the same periodal failures. My postcode is PH33. I can't find a phone number to speak to a human being, to determine whether it's an area engineering problem or if my hub is faulty. Would someone from Sky please provide answers and assistance. Thank you.
03 May 2024 12:24 PM
Posted by a Superuser, not a Sky employee. Find out more@JohnnyGG When you say the hub is failing what lights on the hub are going out or is the hub doing a power cycle?
03 May 2024 01:47 PM
It's the internet and voice lights which keep going orange.
03 May 2024 09:07 PM
Posted by a Superuser, not a Sky employee. Find out more@JohnnyGG Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
Do this on a mobile device while the issue is happening.
