Discussion topic: How to turn off 5ghz option on my own white router
Message posted on 26 Oct 2024 09:30 PM
I have Teckin Smart switches to add to Alexa, trouble is they don't like 5ghz only 2.5ghz as they clash. How do I switch 5ghz on and off on my white router.?
Message posted on 26 Oct 2024 09:58 PM - last edited: 26 Oct 2024 10:08 PM
Re: How to turn off 5ghz option on my own white router
Max Hub administration is largely carried out in the My Sky app.
https://www.sky.com/help/articles/change-wifi-max-hub-settings
Open the My Sky app.
Tap Product Settings on Home or the Broadband tab.
Tap Sky Max Hub.
Tap Disable WiFi.
Tap Sky Max Hub from the Disable network list.
Toggle 2.4 GHz or 5GHz to off.
