Discussion topic: How to remove Amstrad in my skystream puck
This message was authored by: L00neytune
Hi I need help on how to get rid of Amstrad in my skystreaming puck!
Re: How to remove Amstrad in my skystream puck
@L00neytune
Do you perchance have an lg tv.  Happened to me and a few others on the forum .  You just need to rename the "amstrad" as "sky stream" in the tv settings. Not near tv at the mo but will updateas soon as i can
@L00neytune
Step-by-step guide:
• 1. Press the Home button:
Locate and press the Home button on your LG remote to bring up the Home Dashboard.
• 2. Access Edit Inputs:
On the Home Dashboard, navigate to the top right corner and select the three vertical dots icon.
• 3. Select Edit Inputs:
From the options that appear, choose Edit Inputs.
• 4. Choose the input to rename:
You will see a list of all your connected HDMI inputs; select the one you want to change by clicking on its banner.
• 5. Type a new name:
An on-screen keyboard will appear, allowing you to type a new name for the HDMI input, such as "PlayStation" or "Apple TV".
• 6. Save your changes:
After typing the name, select Enter or the Save button to confirm your changes. The input is now renamed and will display the new label when you select it.
Its to do with the way the tv interprets commands sent via hdmi so the remedy is via tv settings not the puck
