Discussion topic: How to receive WIFI into a summerhouse
This message was authored by: Hawkeye69
Message posted on 10 Dec 2025 03:59 PM
Hi guys, we have had a summer house fitted at the bottom of the garden, it does pick up the wifi but the connection is slow and just buffers or loses connection thay wont find the network again.
Ayy advice on what we need please?
Darren
Message posted on 10 Dec 2025 04:43 PM
Re: How to receive WIFI into a summerhouse
@Hawkeye69 If you have power in the summerhouse connected back to the home, powerline is one way to do it and may work, the other is to run an Ethernet cable from the Hub to the outside then add additional WAP that for sure will work!
