Discussion topic: How to make my WiFi turn off at 12am
This message was authored by Paulmorgan84 This message was authored by: Paulmorgan84
How do I make my WiFi have a scheduled downtime.
Looked online but can't find much.
Did find something but when it asked me my sky I'd and password it doesn't do anything.
Re: How to make my WiFi turn off at 12am
@Paulmorgan84 the only easily controlled Sky hub is the one that comes as part of the Wifi Max bundle which has parental controls enabling you to control access for each device. Otherwise the only simple way to control a hub is to connect via a time switch.
In theory you can programme the other hubs to block access between certain hours by creating a rule to block all devices access and then set a schedule. You can access the web interface by typing 192.168.0.1 into a browser when the web interface loads click on Advanced and log in using the user name admin and the password which will be.either sky or the Hub's default wifi password depending on the model. It is fiddly and quite easy for determined kid to get round.
