Discussion topic: How to log on to sky wifi
This message was authored by: aitch12
I used to be with Virgin, who moved me to O2, that was expensive so chose sky. my wifi still shows  i'm logged on to VM0709703, my old virgin wifi. how do I get sky wifi working
Re: How to log on to sky wifi
You need go to settings on your device, get it to search for all Wifi networks then connect to the one that is yours by entering the network key (password) that should be printed on the broadband hub.
