Discussion topic: How to get WiFi in garden room
This message was authored by Kerr1 This message was authored by: Kerr1
I have an Ethernet cable and ports but need WiFi in garden room
Re: How to get WiFi in garden room
@Kerr1
Are you saying you have an ethernet cable running down to your garden room?
I am NOT a Sky Employee
Kerr1
Yes but now need WiFi for mobile devices. I am with sky and brought a second router but not sure if this is needed or if a need a sky booster box? Any help appreciated as not technical!
@Kerr1
Ah okay, a second router wont work. What you need is a Sky booster or purchase your own 3rd party Access Point
@Kerr1
A second router typically isn't appropriate, and on default configuration may knock out broadband to the rest of the property.  A Sky booster would work, but Sky won't supply one for that purpose.
Kerr1
Thanks I'll get one!
