Discussion topic: How to connect my own router to Sky Broadband?
This message was authored by: Crystal12
can I not using Sky Hub but using my own WIFI router ?
Re: How to connect my own router to Sky Broadband?
@Crystal12
What connection do you have . Fttc superfast or fttp ultrafast ?
What router do you have or are looking to get?
Avatar for Crystal12
Ultrafast
I would like to connect to my ASUS RT-AC87U . How to set up ?
@Crystal12
What connection do you have?
That router should work direct connected to a fibre optic ont or in conjunction with a vdsl modem for fttc
However you can just switch wifi off on the sky hub and ethernet the asus (in access point mode) to the sky hub
While opt in my router, I am requested to enter my user name and ID. Is it normal ?   Where can I find my login ID ?
@Crystal12  Which router did Sky supply you for your service from the link below..
