Discussion topic: How to connect my door camera to my wifi because it wont
Message posted on 15 Nov 2024 12:16 AM
Message posted on 15 Nov 2024 07:04 AM
Re: How to connect my door camera to my wifi because it wont
@Ian217 if the camera is mounted on an external wall the WiFi signal level will be greatly reduced. You may need a WiFi booster in a window near the front door. Sky never guarantee wifi coversge outside your home.
Message posted on 15 Nov 2024 08:13 AM
With a white Max Hub you may need to reduce the wireless security level from WPA3 to WPA2-PSK using the Hub settings in the My Sky app.
You can use the same settings to temporarily disable the 5Ghz WiFi band: remember to re-enable it afterwards if you do this.
