Discussion topic: How to connect broadband and TV to outdoor bar
This message was authored by Gordonwalker This message was authored by: Gordonwalker
Hi. Wondering if someone can help me, I've just installed a outdoor bar and was wondering how to get sky broadband and TV connected to my bar.
Re: How to connect broadband and TV to outdoor bar
@Gordonwalker by far the best solution is to run an ethernet cable from your Sky hub to the bar use external grade cable. Connecting by WiFi maybe possible but can be far more expensive.
Connecting the TV or Sky TV box by ethernet will work and you can add a WiFi access point if you need WiFi in which case a simple ethernet switch may be needed so multiple ethernet ports.
