This discussion topic has been answered Discussion topic: How to connect a NVR wirelessly to hub
Message posted on 13 Sep 2025 10:09 AM
Hi all, I've just switched from VM to sky and now my hub is located in a different room to my NVR which was previously connected to my hub via a short lan cable, the NVR doesn't have any wireless connection capability. I don't really want to use a very long lan cable as I'm unable to hide/conseal it so my question is can I connect the NVR wirelessly to my sky hub and if so what kit do I need to buy. I'm not a tech expert, more a plug and play capability type person so please don't get the technical on me.Many thanks.
Message posted on 13 Sep 2025 03:53 PM
Thank you TimmyBGood,
I purchased
TP-Link TL-PA7017 KIT Powerline, Pack of 2
it contained two short Ethernet cables which was a bonus, the info doesn't say that it includes these cables.
it was very easy to set up and it works a treat, great result👍
Message posted on 13 Sep 2025 10:14 AM
Re: How to connect a NVR wirelessly to hub
The situation is inherently technical, but the simplest solution would be to acquire a pair of Powerline networking adapters.
I purchased
