Discussion topic: How to connect Eufy camera and base unit to ne router.
Message posted on 30 Nov 2024 11:47 AM
I understand that the Eufy camera requires 2.4GHz broadband and cant cope with 5GHz. I have established that Channel 11 in the new roiuter is at 2.4GHz but I have no idea how i get the Eufy to pick up on this. I have read that it is possible to turn off the 5GHz chanel until the camera connects but again have no idea how to do this.
Any help will be appreciated as I reallu have no clue about computers.
MrH
Message posted on 30 Nov 2024 11:59 AM
Re: How to connect Eufy camera and base unit to ne router.
With a white Max Hub you may need to reduce the wireless security level from WPA3 to WPA2-PSK using the Hub settings in the My Sky app.
You can use the same settings to temporarily disable the 5Ghz WiFi band: remember to re-enable it afterwards if you do this.
Message posted on 30 Nov 2024 12:56 PM
Thanks Timmy I will have a look.
