7
This discussion topic has been answered Discussion topic: How long to wait for Sky FTTP Broadband activation
This message was authored by: Purpleivan
I'm buying a house where I plan to sign up for Sky Broadband (Ultrafast+) and I'd like to find out how long activation of the connection typically takes, from the day that it's signed up for, to when it goes live, so that I can sign up in time for my move.
Does anyone have info on this?
Re: How long to wait for Sky FTTP Broadband activation
@Purpleivan
I'd suggest doing so once you have a moving in date: there's inevitably a lead time even when the connection infrastructure is already in place, and this is usually quoted as ten working days.
@Purpleivan
Does the property already have a Openreach optical connection and ONT?
This can be established by
Putting the address into the BT Wholesale Availability Checker.
@Purpleivan
If the FTTP infrastructure isn't already in place then it needs to be physically installed, and that process cannot start until you are in residence to give the necessary permission.
Avatar for Purpleivan
Level 2 icon
Hi @TimmyBGood
There seems to be ONT active at the property.
@Purpleivan
That's a good sign, and hopefully the departing occupants will leave it in place.  You won't be able to place an order with Sky until they've notified their current ISP (even if that's also Sky) that they are moving out.
Level 2 icon
Thanks for that info @TimmyBGood
Once the current owner gives notice to their broadband supplier that they are leaving the property, how long should I allow for the period from contacting Sky to arrange my broadband service to that service being activated?
@Purpleivan
Level 2 icon
ok, thanks for the confirmation of the 10 working days time. That should fit in well with my plans.
