Discussion topic: How do i log out of all devices on my sky max hub
This message was authored by: Mummyminions
Hi iv just had fiber installed iv logged into my router and it's showing 12+ devices logged in how do I log out of all devices??iv tryed to change password and it's changed but not logged out of anything they are all still running on the original password
Re: How do i log out of all devices on my sky max hub
@Mummyminions
You can't 'log devices out' of WiFi thats not how it works. Changing the password should disconnect all WiFi connected devices, but not wired. If devices are still connecting using your old password then you must have something on your network that is keeping the same SSID & Password such as a extender, booster or Sky Q.
I am NOT a Sky Employee
Avatar for Mummyminions
Iv nothing connected no extenders pods or sky q and still they won't disconnect after changing password
@Mummyminions
Have you actually checked that the devices are connected or not? They may still show up on the Sky account device list for a period of time after you change the password.
Are you sure your new password is applying correctly? Can you post a screenshot of where you are changing the password?
