Discussion topic: How do I set up WiFi sockets, need to disable 5GHz from router & login to 2.4GHz
This message was authored by: Jack8731
Needing to disable the 5GHz on the broadband to set up WiFi sockets on the 2.4GHz frequency.
Re: How do I set up WiFi sockets, need to disable 5GHz from router & login to 2.4GHz
@Jack8731
Which hub do you have er115, sr203 or sr213 ?
For the first 2 follow the instructions below
https://helpforum.sky.com/t5/Broadband-Talk/How-to-separate-WiFi-bands/ba-p/3530610
