7
Discussion topic: How do I eliminate WEAK SECURITY
This message was authored by Bobo This message was authored by: Bobo
My iPhone 11 keeps saying that I have weak security and it's needs changing in sky settings which I can't access. WPA2 need changing to WPA3 , how do I do this ?
This message was authored by Chrisee This message was authored by: Chrisee Answer
Re: How do I eliminate WEAK SECURITY
@Bobo Wpa2-psk is still basically secure and only very new routers support wpa3 which is admitedly better. No isp is going to dump several million operational routers because a new standard has been developed so do as virtually everyone does which is ignore Apple's warning.
@Bobo
Only the new Max Hub supports WPA3
The Sky Hub, Q Hub and Sky Broadband Hub are all WPA2 or below, and cannot be updated because WPA3 has a hardware component.
This message was authored by swain88 This message was authored by: swain88
Buy tp-link router, much better quality and more options
This message was authored by Frustrated+of+Lew This message was authored by: Frustrated+of+Lew
Unfortunately, some apps no longer work. WhatsApp most notably, and sometimes photo loading on Facebook. Resolved by switching to 4g
Bobo
Sadly Dky have zero interest until you write to your MP. Soon got sorted then! Shame on you Sky for having zero interest
@Bobo  If you are using an Apple IOS device that wants WPA3 as the default seciurity level where most ISP routers are on WPA2 and newer models coming out and you will find that most ISPs are playing catch up all the time.
Then you have to think that not everyone can have the newest devices and have to use older hardware.
I seriously doubt a typical MP knows WPA3 from SW1A.  Also difficult to imagine their intervention would influence the view  of the Apple Corporation on minimum desirable levels of wireless encryption very much.
