Discussion topic: How do I change the WiFi security settings from wmp 3 to wmp2 to enable me to use my I pad
This message was authored by: JHP7
My I pad will not connect to the internet. I want to change wpa3 to wpa2
Re: How do I change the WiFi security settings from wmp 3 to wmp2 to enable me to use my I pad
@JHP7
You need to login to your broadband hub and make the change:
Open your browser and type 192.168.0.1 into your address bar.
When prompted enter the username: It is admin and the password is either: sky OR, your WIFI password.
@JHP7 if as it sounds its a white Sky Max hub the setting should be in the My Sky app in the Advanced setyings area for the hub not in thecweb interface.
