4
This discussion topic has been answered Discussion topic: How do I change my Wi-Fi from 5GHz to 2.4 GHz?
This message was authored by: Anita16
Hi, I need to temporarily switch to 2.4 GHz as I want to add my smart bulbs. How to I change from 5 GHz.  Thanks for any help.
Avatar for Anita16
Level 2 icon
This message was authored by: Anita16 Answer
Re: How do I change my Wi-Fi from 5GHz to 2.4 GHz?
@cookiemonsteruk it worked and all the smart bulbs have been added.  Thanks for your help and advice.
@Anita16
You can seperate the two wifi bands as shown below
https://helpforum.sky.com/t5/Broadband-Talk/How-to-separate-WiFi-bands/ba-p/3530610
Avatar for Anita16
Level 2 icon
Thanks @cookiemonsteruk , I'll have a go tomorrow, would I just repeat the steps to turn 5GHz back on after I've installed the smart bulb?  Many thanks.
@Anita16
The easiest way if you want to revert would be to log on as above and untick enable wifi do the change and then tick it again
The method above i used so as i could add 2.4 devices without going thru the whole disable/enable everytime
Avatar for Anita16
Level 2 icon
