3
This discussion topic has been answered Discussion topic: How can I turn Wi-Fi back on. sky q ES340A
This message was authored by: Bd15
I've just given up creating a new mesh network with deco devices and am back to just using my SR203 sky hub, ES340A Q box, and one sky booster. I am going to add wired back haul instead to improve the sky mesh.
Anyway... as part of trying to get the decos working well with the sky Q box I accessed the 001 engineer menu and disabled the Wi-Fi. it took me about 30 goes to get the menu to appear.
Now I need to turn the Wi-Fi on the Q box back on again as the box cannot connect to Wi-Fi and I also need the booster functionality.
However I cannot get the 001 engineer menu to show. I have tried 100 times!   I am confident I have the sequence correct and have tried various timings for button presses but to no avail.
 Can someone help me either get the engineer menu to appear or another route to turn those setting back on.
Re: How can I turn Wi-Fi back on. sky q ES340A
@Bd15 Navigstecto the wettings menu and then enter 0,0,1 before hitting select if you select before entering the code it wont open the engineer's menu
Avatar for Bd15
Thank you.  This is what I have been doing and I can't get the menu to appear
Avatar for Bd15
Actually you were right. I was looking at a site that said..... settings, setup, 0,0,1,select.  I should be on settings, not set up.  Thank you
