Discussion topic: How can I get faster broadband installed?
This message was authored by minimoe This message was authored by: minimoe
The post-code checker says I'm on the fastest in my area, for all ISP's available in my area. My neighbors further up my street have Fibre with BT and Virgin Media. I'm on 59Mb right now (with Sky).
How would I get a fibre line installed? Am I stuck with this for now?
Re: How can I get faster broadband installed?
@minimoe
Enter your full postal address below and post the table after removing your address from the image
minimoe
Table attached, doesn't look promising
@minimoe
It looks like the fastest speed is 42Mbps so isp's round that down to 40Mbps. Not looking good at the moment
minimoe
Is that the fastest speed available right now, or in general? I'm paying for a 59Mb connection. Is this Sky being weird with their advertising? The word "average" is used a lot. Seems kinda sneaky. I get nowhere near these "average speeds" at any time.
@minimoe
59Mbps is a national average which advertising standards permit isp's to quote.  So sky and no doubt other isp's are within their right to quote that figure
@minimoe
FTTC speed is entirely dependent on the distance from the local fibre cabinet to the subscription address over copper 'phone' cable: an ISP cannot deliver more speed than the laws of physics permit.  FTTC tops out at 80Mbs and drops from there: as @cookiemonsteruk indicates, ISPs are permitted to advertise using a particular form of 'average' which some of their customers simply cannot get.
@minimoe
It sounds like you have been unlucky and not connected to the full fibre network that your neighbours up the road are. This can often happen if Openreach decide its not worth the cost to continue the fibre deployment all the way up the street or if they find a limiting factor to stop the deployment.
You can use this site https://www.openreach.com/fibre-broadband to see if it will give you an idea of Openreaches plans for your area, usually it'll either say 'We dont have plans yet to build in your area' or 'We are starting to build in your area'
I am NOT a Sky Employee
