14 Sep 2022 01:10 PM
Hi there,
Just that really, how can I find it?
Cheers, Tudor.
14 Sep 2022 01:20 PM
Posted by a Superuser, not a Sky employee. Find out more@Dirty+Tudor The wifi pass code is printed in a label on the back of, or underneath your sky hub.
14 Sep 2022 01:37 PM
Is it the same as my wifi passcode? I'm trying to disable 5ghz so I can use a device that only uses 2.4ghz, really struggling to find out how...
Cheers, Tudor.
14 Sep 2022 01:40 PM
Seperate the wifi bands so you have 2 ssids's in order that you don't lose out on the faster 5ghz
https://helpforum.sky.com/t5/Broadband-Talk/How-to-separate-WiFi-bands/ba-p/3530610
20 Sep 2022 10:47 AM
Your WPA-PSK is your WiFi password. They are the same thing
