Discussion topic: How can I change router speed (GHz). Can’t connect Sonos Playbar
This message was authored by: ChrisF3
I understand router speed may be the issue here but can't find out how to change it.
Re: How can I change router speed (GHz). Can’t connect Sonos Playbar
@ChrisF3
GHz is frequency rather than speed.
Do you have a black or a white Sky Hub?
Avatar for ChrisF3
Hi, thanks for your response. It's a white router.
Avatar for ChrisF3
Resolved!
2 things here. Firstly, once I gained access to the router settings (simple to some, but tantamount to a black art to me) I could see that different WiFi enabled devices were connected at different frequencies (apparently automatically because I certainly hadn't done anything!) so I thought perhaps that wasn't the problem. Another forum thread I had going concerned the poor Wi-Fi range of my Skymax hub. A very helpful forum member (thanks JimM1!) suggested I change the router settings to WPA2. Once I did that, not only did the Wi-Fi range improve (not massively, but noticeably) but suddenly the Sonos Playbar connected up to Wi-Fi and everything working again.
Gret, very pleased and thanks to all.
