Discussion topic: Home TV is not able to connect to broadband or continuously getting interrupted
Message posted on 16 Nov 2025 08:59 AM
On my TV it says, please ask the router if the MAC address off the router is registered. How to resolve this issue.
The WiFi is being continuously disconnected from last 2-3 days.
Message posted on 16 Nov 2025 09:49 AM
Re: Home TV is not able to connect to broadband or continuously getting interrupted
@Vikranth ignore the error message it is essentially rubbish as Sky hubs like virtually all routers do not limit connection by registration of mac addresses.
There are several possible causes. Firmware upgrades can cause issues so check the TV's network settings in particukar turn off any network energy saving options. If you have a white Sky hub check the wifi security setting is on WPA2 you will find thst in the advanced section of the hub's settings in the My Sky app. Hopefully thst will sort the issue.
