3
This discussion topic has been answered Discussion topic: Hi my internet at home keeps dropping out and cant connect
This message was authored by: jopearse1221
Hi my children  have to.keep re connecting to our WiFi and can't play on there games however rhe WiFi.is connected. Please can ypu help. Keeps saying dis connected. Please check.yr Internet. Connect and try again. Error code 277. Many thanks
This message was authored by: Highlinder Answer
Re: Hi my internet at home keeps dropping out and cant connect
@jopearse1221 Can you please run the service checker, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker completes and if it comes back green all good can you click on broadband to run an updated test please. If you get amber or red please follow the on screen instructions.
Avatar for jopearse1221
Hiya, thanks for Yr reply, I have done all this buy comes back as fine!
Hiya I've done all this many times but will do it again, thanks for replying!
