Discussion topic: Hi my broadband has suddenly stopped working
Message posted on 12 Jun 2024 02:23 PM
Message posted on 12 Jun 2024 02:39 PM
Re: Hi my broadband has suddenly stopped working
Yesterday at 9:30 am I was leaving home and everything looked fine. Until I arrived from work after 11hours after and the broadband wasn't working, wich I taught it was strange has i paid my bill one month ahead. So I don't know how long it's gonna take to fix this but despise being a GoldVIP for 7 years and get this treatment is a bit sad. Hope you can fix this as fast as possible, thanks and wish a good day.
Thanks,
Ernest Jimenez
Message posted on 12 Jun 2024 02:55 PM
@Gabby30 & @ErnestJimenez Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
Message posted on 13 Jun 2024 01:00 PM
Definitely not working still, so can i have a engineer to check it?
Thanks.
Message posted on 13 Jun 2024 01:09 PM
@ErnestJimenez What did the broadband test tell you about your connection? Did you also check the service checker to see what it said about your connection in the area?
Message posted on 13 Jun 2024 04:11 PM
Hi, the PON light keeps just flashing instead of a continuous stopped light and the internet light from the sky hub doesn't show green light, just green light in the power and wifi only.
Message posted on 13 Jun 2024 04:47 PM
@ErnestJimenez What colour is the LOS light on the ONT?
Message posted on 14 Jun 2024 02:28 AM
Well i don't even have a green light on LOS so light off, just Power that is on and not blinking,LAN is on but a more stable light PON just blinks on and off and like i said in the Beginning its of the Los light is off.
Thanks.
Message posted on 14 Jun 2024 12:10 PM
that's how it looked so far in all days and today all is on and not working but test shows this.
But all is connected and on but no internet connection 😕 so I do believe EITHER I need a engineer for this or probably a new hub but like I said, I've been 7 years gold member for sky and still no improvement in fixing it as should be and promised to for VIP's members. And normal customers.
Message posted on 14 Jun 2024 12:16 PM
@ErnestJimenez What happens when you click on looks like a problem with your Sky broadband?
With no light on the PON would seem that you are getting no signal from Sky. Have you tried to check to see what that problem is without having to call and get this sorted out. But if it says to call just come back there is further help the community forum can give.
