Discussion topic: Hi my WiFi is not good speed, some time is not connection also
This message was authored by: Singajoshi
Hi
my wife is not coming good speed,
some times wife not connecting also,
please fix this problem as possible
Singajoshi
Re: Hi my WiFi is not good speed, some time is not connection also
@Singajoshi Posting on the Forum you are not talking to sky, just customers like yourself, the community page above and About explains it all, so if help is needed then you need to supply the detail, if sky is required to help you then you have to call them!
Avatar for Singajoshi
@JimM1
Ok ,
by the way not wife, it's WiFi..
thanks for replying & explaining.
@Singajoshi It was worked out did have a chuckle at it though! Good speed next to the hub where you have it, elsewhere a problem then sky Max boosters are what you are going to need from them! New wife not going to happen!🤣
