Discussion topic: Hi help needed my broadband in my bedroom is dipping out
This message was authored by: Sue197070
I live in a small bungalow all on one floor and broadband in bedroom is lucky to hit to bars causing my tv to spin at times . What can I do ?
Re: Hi help needed my broadband in my bedroom is dipping out
@Sue197070   Try the steps here https://www.sky.com/help/home/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/arti...
Avatar for Sue197070
Done all this shouldn't need a booster in such a small property  ? Maybe have to go else were
@Sue197070
If there is other WiFi signals interfering in the airspace, then yes you may well need a booster in such a small property.
If your router is position in a poor location such as low down, inside a cupboard or covered by something, then yes you may well need a booster in such a small property.
If you have lots of appliances causing noise or blocking line of sight from the router, then yes you may well need a booster in such a small property.
If you have many devices connected to the router, then yes you may well need a booster in such a small property.
The size of a property is not always key to the WiFi performance.
I am NOT a Sky Employee
