Discussion topic: Hi, I’m having issues connecting an Xbox
This message was authored by Faz13 This message was authored by: Faz13
My lads Xbox was working fine on the WiFi network and dropped off for some reason. Reset router and Xbox with no luck, thinking it's my WiFi I managed to connect it to a neighbours network and it worked fine! What's wrong or what do I need to do to get the Xbox back on my WiFi? Save me a headache from a grumpy teen!🙄cheers.
Re: Hi, I’m having issues connecting an Xbox
@Faz13 Do other devices connect properly if so its an issue with the xbox first reboot the unit as the network connection msy have become corrupted.
Faz13
@Chrisee  thanks no problem with other devices and took the Xbox to a friends house to try it and it connected to the WiFi straight away???🤷‍♂️
