Discussion topic: Hi, I have damaged my sky hub cables and need them replacing. How do i do this please?
This message was authored by Chris1234543211 This message was authored by: Chris1234543211
This message was authored by mae-3 This message was authored by: mae-3
Re: Hi, I have damaged my sky hub cables and need them replacing. How do i do this please?
@Chris1234543211
Which cable(s) and are you on fibre to the cabinet (FTTC) and twisted pair with a telephone socket for broadband or full-fibre with an ONT and connected by ethernet to an optical network terminal (ONT)?
Zen internet on FTTP (900Mbps down, 100Mbps up). SAT> IP (Apple 4K 2nd gen TV to LG C1 OLED UHD TV/Dolby Atmos Denon AVR, DacMagic Plus for Hi-Res audio), hosting own blog/forum (cluster), OPNsense & Zenarmor L4/L7 NGFW & DPI IDS/IPS, Asus ET12 Pro Tri-Band wifi, Linux, Gamer: Xbox Series X/i7 laptop, round-robin DNS over HTTPS, non-proprietary VoIP HD AMR-WB (G.722.2) and more... Beta tester Apple iOS/watchOS/tvOS/iPadOS/macOS. Dr Mae-03 PhD.
@Chris1234543211
Either way, if you have damaged the cable going to the telephone socket, you'll need an RJ11 to RJ11 cable and microfilter if you don't have a pre-filtered faceplate. Or an ethernet cable cat 5E or above for ONT.
Both these can be purchased from most electrical stores.
@Chris1234543211  This is not the power cable to the hub is it?
@Highlinder & @Chris1234543211
If it is the power cable then Sky doesn't provide those and you'll need a new router from Sky and are likely to have to enter into a new contract for the period in question, usually 18 months or 2 years!
@mae-3  Normally if the power lead is damaged they replace the router. But never heard of them demading the user takes a new contract for the new router to be sent out.
@Highlinder
Hopefully, it is not an old router that needs replacing and Sky obliged with a free new router without a contract extension... 😎
@mae-3  If it is the older Sky Q router then they will change it out for the newer 4.2 router as the older Sky Q routers are being phased out. But will just have to see what @Chris1234543211  does tell us which cable it is that is broken.
Chris1234543211
The cable is the one that goes from the phone  socket to the small splitter box thingy
@Chris1234543211
The cable you need is an RJ11 to RJ11 cable and these can be purchased from places like Amazon for a few pounds.
@Chris1234543211  Take that to an electrical shop and ask them to show you a new one to purchase.
