Discussion topic: Help,do I need to leave to the 2boxes plugged in and switched on 25hours
This message was authored by: GRIFFO1
Just got sky fibre broadband,do I have to leave it on all the time.Worried the plugs might get too hot
Re: Help,do I need to leave to the 2boxes plugged in and switched on 25hours
@GRIFFO1 the hub and the ONT are designed to run 24/7 and actually use minimal power so the plugs should not get hot ideed if they do something is clearly wrong.
@GRIFFO1
All such devices are designed, specified and manufactured to be plugged in and switched on all the time: repeated power cycling can be harmful and interfere with normal operation.
