Discussion topic: Having trouble setting up Teckin Smart plugs on white router.
This message was authored by: Notabilis
Having trouble setting up Teckin Smart plugs on white router, what do I need to do?
Re: Having trouble setting up Teckin Smart plugs on white router.
@Notabilis  You will need to go into the settings of the router and lower the security setting from WPA3 to WPA. You might also have disable 5.0GHz band for a short period of time to enable you to connect the smart plugs.
Avatar for Notabilis
Thanks @Highlinder
