Discussion topic: Having problems connecting my printer to the my Sky Max router so can not print using Wi-Fi connecti
Message posted on 19 Nov 2024 04:34 PM
Trying to connect my hp Deskjet 3050 printer using WPS button but it will not connect
Message posted on 19 Nov 2024 04:40 PM
Re: Having problems connecting my printer to the my Sky Max router so can not print using Wi-Fi conn
With a white Max Hub you may need to reduce the wireless security level from WPA3 to WPA2-PSK using the Hub settings in the My Sky app.
You can use the same settings to temporarily disable the 5Ghz WiFi band: remember to re-enable it afterwards if you do this.
Message posted on 21 Nov 2024 02:48 PM
Hi I tried with changing the wireless security level from WPA3 to WPA2-PSK and it still would not allow the printer's WiFi connevtion to be established /make?
Message posted on 15 Feb 2025 12:36 PM
I've done this. And my printer connected, but when I went back to the more secure setting it would not connect. Does this mean to use my printer I would have to have the riskier setting?
