3
This discussion topic has been answered Discussion topic: Having an issue with my blink camera disconnecting from the WiFi
This message was authored by: Philcathy1
while I'm at work on nights my blink camera goes offline at the same time every night 02.30 am for about 4 hours then reconnects does anyone have a similar problem or know of any fix
This message was authored by: jamesn123 Answer
Re: Having an issue with my blink camera disconnecting from the WiFi
@Philcathy1
If you have any Mini boxes you may need to change the setting on those too
I am NOT a Sky Employee
@Philcathy1
That sounds like your Sky Q box/s are going into Eco mode which means they stop boosting your WiFi signal around the home. You can disable Eco mode on each box to stop this happening.
https://www.sky.com/help/articles/using-the-standby-settings
Avatar for Philcathy1
Thank you very much I've changed the settings in my sky Q box from eco to active now do hopefully cured , much appreciated for that help
@Philcathy1
