19 Jun 2022 01:57 PM
Can Sky WiFi be accessed without Sky Buddy to see what devices are on my WiFi?
19 Jun 2022 03:29 PM
Posted by a Superuser, not a Sky employee. Find out more@burds1If you run a broadband test, via the Sky app it shows you the number of devices connected to the network. So if you know the number that is supposed to be connected, you will then know either way what devices are supposed to be on and what ones are not.
Some of them are not named, so you would have to go into the settings of each device to find out which device is which.
Also you able to login on the router and see the devices connected to the network.
19 Jun 2022 06:03 PM
Thank you. Can you advise how to log onto the router?
19 Jun 2022 06:40 PM - last edited: 19 Jun 2022 06:41 PM
Posted by a Superuser, not a Sky employee. Find out more@burds1To login on the router, put in the address bar and not the search box. 192.168.0.1, the information you are looking for is the page that is displayed when you login.
Do not add the coma just after the 1.
19 Jun 2022 11:50 PM
Thank you for all your help, much appreciated
