Discussion topic: Had Fibre installed 5 days ago. Wi-Fi not working. Is this normal?
Message posted on 14 May 2024 08:36 PM
I read that Fibre speeds will be up and down for 10 days but not sure if that also means WiFi. Can't see anything online about that.
checked on the Sky app and it says "Wi-Fi is working" well but it isn't. It is connected but pages don't load. I have tried everything including logging in and out etc. please help
Message posted on 15 May 2024 07:41 AM
Re: Had Fibre installed 5 days ago. Wi-Fi not working. Is this normal?
@SFW Sky donsay that connection speeds to the hub can vary in the first 10 days which is true for servicescover copper phonelines but not for full fibre. Speeds over wif in your home are outside their control as they are down to the layout and type of construction of your home and the level of interference. In many homes a single wifi router is insufficent to provide fast wifi in every room.
Sky sell an add on package called Wifi Max which can help,as they will supply up to 3 extenders if they agree you need them. Alternatively you can buy third party kit.
Message posted on 15 May 2024 07:54 AM
Thanks for the reply. The Wifi was working fine on sky broadband but yet on Fibre it has stopped working.
Can I phone Sky to get this looked into?
