Discussion topic: HOW AN EARTH DO I SPEAK TO SOMEONE ON THE PHONE
Message posted on 06 Apr 2025 05:27 PM
Ring up they tell me to go on to the website but can't get on the website because the router is down! I need to speak to someone asap
Message posted on 06 Apr 2025 05:39 PM
Re: HOW AN EARTH DO I SPEAK TO SOMEONE ON THE PHONE
@Tylermaiden30
To call Sky dial 150 (free) from your Sky Talk landline or a Sky mobile. Alternatively use this link…
https://www.sky.com/help/home
UK customers: Scroll down and click on ‘Need more help’ leading to a number starting 0333.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ to see a dedicated ROI number. (Customer Services in the ROI are not open at weekends).
The posting of full phone numbers isn’t permitted on the forum.
Calls to Sky will initially be automated which may try to send you here to the forum, offer you online help or offer to send you a text. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
