Discussion topic: Guest Wifi for an Airbnb
Message posted on 04 Jul 2025 06:56 AM
Hi
I know been asked before buy I can't find a definitive answer / solution.
We have sky black hub and 2 white boosters, we need to add a guest wifi for our Airbnb.
We want to be able for them to have a seperate login and also be able block inappropriate site access.
I know sky doenst have the facilty, so what do we do?
Please answer in simple terms! As this is all complicated for us! If we need to buy anything else / switch anything please can you suggest whats you think would be best.
Or is it a case of ditching sky and finding a different supplier?? We really have no idea!
thanks
Doug
Message posted on 04 Jul 2025 07:54 AM - last edited: 04 Jul 2025 08:00 AM
Re: Guest Wifi for an Airbnb
That's effectively business use which no domestic ISP is well positioned to supply and support.
Having 'guest' WiFi may be supported on some ISP routers, but differential web filtering is rather more complex.
Message posted on 04 Jul 2025 07:58 AM
@dougstour leaving aside the contractual issue which limits use to your household's domestic usage no Sky hubs offers a guest network facility. You could buy a third party mesh WiFi access point system like the one I have which does offer a guest network and use thst to give wifi access behind your Sky hubs.
Message posted on 04 Jul 2025 09:27 AM
@TimmyBGood Take it you have not been moved by BT to the darkside yet!
