Discussion topic: Got told to upgrade for the Internet to still not work
Message posted on 31 Jul 2025 12:22 AM
Message posted on 31 Jul 2025 04:44 AM
Re: Got told to upgrade for the Internet to still not work
@M13A
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
Remember that Sky broadband being discussed here is a domestic service and whilst it's fine for those customers working from home to use it, they won't receive additional or quicker support.
