Discussion topic: Got the new wifi max and it’s still so low browsing on the internet and sometimes doesn’t loaded up,
This message was authored by: Adrian333
Message posted on 23 May 2024 10:50 PM
Got the new wifi max and it’s still so low browsing on the internet and sometimes doesn’t loaded up,I've checked the db readings of the router and I'm getting -65 min right next to the router , what's the issue anyone help ?
Find out more
Message posted on 24 May 2024 07:10 AM
Re: Got the new wifi max and it’s still so low browsing on the internet and sometimes doesn’t loaded
@Adrian333 you can get low signal very close to the hub due to interference patterns caused by the multiple aerials so if you are literally within inches try moving further away say roughly a metre when taking measurements. My own SR213 Wifi Max hub gives a signal strength of -30dBm at that point.
