Discussion topic: Got no fibre
This message was authored by: HairyRunner
Got no fibre
Says theres no problem but I've got no fibre
Re: Got no fibre
@HairyRunner if you mean your connection is down (see https://www.sky.com/help/articles/hub-lights-explained-start) and the servicecchecker is not telling you Sky are aware of an issue then call them to report the fault.
