Discussion topic: Google Wifi Pro with Sky Full Fibre (FTTP)
This message was authored by: Tweedskin
Re: Google Wifi Pro with Sky Full Fibre (FTTP)
I'm not sure if anything has changed, but I had my Sky Fibre 500 installed today. Once the engineer finsished installing the ONT box, i plugged my Google Wifi (old V1 version) directly in to the ONT and it worked.
Previously on ADSL, I had to plug Google Wifi into the sky router (and set it to not broadcast/use wifi). But with FTTP, it's working just fine direct into ONT box and bypassing sky's router entirely.
@Tweedskin If it works and you have NO need for the sky Hub for the landline connection off a landline phone, then run with the google wi-fi. Sky won't support you for it, but as long as it works you are getting what is needed out of it then go with it!
