Discussion topic: Gigamax broadband showing good speed and connection when its not.
This message was authored by: Masoncody+83
I have Sky Gigamax but am recently finding a poor connection. My Sky Glass cant load my playlist as ir says theres a connection issue and its connected via ethernet cable. I cant watch videos in the bathroom on mobile as it keeps buffering but when i run speed tests via Sky or external checkers they also say its a good connection and speed when clearly not.
This message was authored by: peter-marlow+1966
Re: Gigamax broadband showing good speed and connection when its not.
Do you mean gigafast broadband 900mps,  what speed  are you getting to your  hub ?
P c marlow
Do you  have any boosters  as well
P c marlow
Avatar for Masoncody+83
Hi, yes I do have a booster as well.
Is your  broadband  fftp  full fiber to the property do you have an optical network terminal box  or a phone socket  ?
P c marlow
 this is the full fibre optical network terminal box in the  house  for full fibre broadband
P c marlow
Its the full fibre box with the Gigamax package, thank you
@Masoncody+83
I'm not aware of any Sky Broadband product called 'Gigamax'
There's 'Gigafast' and the 'WiFi Max' add-on...
Sorry, yes thats what i have, my previous provider had a max package. Its gigafast with wifi booster.
Im getting 600mps which is good so I dont understand why the wired connection to the sky glass ia bad and the wifi signal is weak upstairs in the house
