Discussion topic: Gigafast Speeds
This message was authored by snowy1985 This message was authored by: snowy1985
Gigafast Speeds
I have sky fttp gigafast.
Speeds to hub look ok according to the hub status page.
ModelSR203
DownStream Connection Speed (999900)
UpStream Connection Speed (115000)
Speeds over wifi on 5ghz are maxing out at 480mb which with this hub been wifi 5 is about right. However connected directly to the hub via cat6 I am getting roughly the same. Surely I should be seeing more?
This message was authored by Killersjp This message was authored by: Killersjp
Re: Gigafast Speeds
Hi. With eithernet cable to my pc i am getting about 900-920mbps. I guess you should be getting  the same speed if your hardware allows it. Im sure there is a setting on the SR203 web address page for the router under eithernet settings make sure thats set to gig or 1gig.
snowy1985
Re: Gigafast Speeds
It's set to gigabit, it maxed out at 720 before. But that was with other devices using the broadband at the time
Re: Gigafast Speeds
@snowy1985
What speedtest site are you using?
Can you please post your router stats
I am NOT a Sky Employee
