25 Jul 2024 01:36 PM
Please can someone help me, I have just moved to SKY for broadband and there isn't any parental controls available for it. Can anyone recommend a work around before I cancel the service and go back to BT. I don't mind buying a new router if it gives me a good service. I've already got a NETGEAR GS308, plugged into it for my wired network, so if there's anything that can control at device level that would be perfect.
25 Jul 2024 01:39 PM
Posted by a Superuser, not a Sky employee. Find out more@Farrars See if the link below helps
https://www.sky.com/help/articles/sky-broadband-shield-start
25 Jul 2024 01:48 PM
Thank you, I can't see how this would allow me to turn off the wifi/internet to individual devices. could be missing it though 🤷♀️
25 Jul 2024 01:56 PM
Posted by a Superuser, not a Sky employee. Find out more@Farrars I believe this link is what you are after but you need sky Wi-Fi max to use it
https://www.sky.com/help/articles/sky-wifi-max-parental-controls
25 Jul 2024 02:07 PM
@SKY1992bf They don't offer sky max with the fibre broadband 🤦♀️ it's so frustrating. I wonder if I need a 3rd party router. Or
just give it all up and go back to BT ☹️☹️
25 Jul 2024 02:59 PM
Parental Controls are built into the white Max Hub, but only activated with the WiFi Max subscription supplement.
25 Jul 2024 03:05 PM
The Max Hub is the default hardware for all Ultrafast FTTP, but Sky won't offer the WiFi Max add-on at addresses with more than one Q Mini box or Q wireless booster.
