16 Dec 2022 03:17 PM
Hello,
I'm moving into a new build home next week and I'm trying to set up a broadband package, when I put my post code in the address shows up but when I click it and go to move on I constantly get a Technical Error and can't go any further.
16 Dec 2022 03:38 PM
Posted by a Superuser, not a Sky employee. Find out moreMay be worth giving Sky, call 0333-759-1583 from any other phone, if you're in ROI, the number is 08-18-50-019-2.
When calling, ignore the message at the beginning and stay on the phone as long as you can. If the system sends a text message and asks you to hang up, don't.
If asked for the reason of the call, just say speak to advisor or cancel, nothing else. Finally you should be put in the queue for an advisor.
16 Dec 2022 04:37 PM - last edited: 16 Dec 2022 04:43 PM
On a new-build property in the UK that normally indicates Openreach haven't connected it/updated their database yet.
Have you been in the property recently? If so does it have an ONT installed and are all the lights green?
16 Dec 2022 04:54 PM
We'll be at the property on Monday so I'll have a look.
I did think it might not have been registered yet so I'll have to find out, hopefully it won't take too long to sort out.
16 Dec 2022 05:16 PM
What does it say here if you put in the address :
If all the Openreach work is complete it should say this just below the table of products :
ONT exists with no active service. A spare port is available. A new ONT may be ordered.
16 Dec 2022 05:45 PM
Looks like the work may have not been finished.
It says we cannot determine broadband availability at this location.
It's weird though as some of the houses on the street are already lived in. I'll have to make a few calls and see.
16 Dec 2022 05:59 PM
If it says that then Openreach haven't started any work to connect the property & you won't be able to order broadband this side of xmas
I know this from experience from earlier in the year.
It'll say "we cannot determine broadband availability at this location" then "network expansion work in progress" (or similar) then "ONT exists with no active service. A spare port is available. A new ONT may be ordered."
The fact there are other houses connected/lived in is irrelevant I'm afraid, that's the way new builds work.
For Openreach FTTP there are 32 (usually sequential addresses) properties connected to one CBT, then the next 32 go on another CBT etc etc. Could be you're on the next CBT, could just be that your property hasn't been connected due to groundworks (underground ducting) there happening later.
On this road there's maybe 30 completed properties on the database, 10 complete build but work not completed by Openreach, 25-30 more listed but showing as "new-build not complete" and the first houses connected here were over a year ago. All the houses here have Virgin FTTP as well and their internal database says much the same.
I think you'll have to wait until the New Year before you get any connection.....
16 Dec 2022 06:23 PM
Yeah that's what I thought to be honest, annoying but I guess it is what it is, thanks for your information and help anyway.
I'll see if I can find out when the work is due to be completed.
16 Dec 2022 06:37 PM
Ours showed as ONT exists with no active service. A spare port is available. A new ONT may be ordered. about a week before we exchanged contracts on the purchase but the house had been complete for about a month before that.
Even then it took about two weeks after we got the keys for Sky to setup the connection/send the router which is pretty standard as there's a 14 day cooloff/cancellation period mandated by Ofcom on consumer services from placing the order until it goes live.
I suspect you're probably looking at mid to end January before you have an internet connection via FTTP given xmas/Openreach backlog due to strikes/weather. Given its a new-build its a different Openreach team who deal with installs and they're pretty fast so maybe not that long as they shouldn't be dealing with repairs etc.
Get a 4G router/cheap mobile service to tide you over if you haven't already. There's plenty of choice on a rolling one month contract if you buy the router yourself.
16 Dec 2022 06:52 PM
I'll have a look at 4G routers now, is there any you would recommend?
17 Dec 2022 07:13 AM
Its tricky recommending 4G/5G routers as its highly dependent on what the chosen providers signal/bands in use are at a specific location. If the location has good/excellent coverage then you can get away with fairly cheap routers, if not then you're looking at more expensive kit.
www.cellmapper.net has a map with phone masts shown on it. You can select various UK providers and it'll show you what masts/bands are in use & also what direction/area the antennae cover. It also often has details like maximum speed observed so that's probably a good place to start.
17 Dec 2022 08:01 AM
Posted by a Superuser, not a Sky employee. Find out more@oliltfc the online system does that when they are specific issues like needing a new line which needs explaining and you agreeing to accept. Call Sky and they will talk you through what needs to be done.
However if your new build does not have the connection fully installed (an Openreach ONT box installed and connected in the property) you may have a delay. Most new builds go straight onto fibre to the home check with the developer what if any network they have installed or contracted with. Sky use Openreach's network and you can't buy their service over third party fibre.
