Discussion topic: Getting 1/5th guaranteed speed from Cabinet to Router, please help!
This message was authored by jessrabbit3 This message was authored by: jessrabbit3
 I recently moved house and have gone with sky broadband as it was the best choice in my area, I'm guaranteed a speed of 55Mbps but am only getting 10Mbps (from cabinet to router - I'm not talking about wifi degredation or anything similar).
Could anyone please help me with this? I rely on the internet for my job 😰
Re: Getting 1/5th guaranteed speed from Cabinet to Router, please help!
@jessrabbit3
Could you post your hub stats
jessrabbit3
jessrabbit3
Router Statistics
System Up Time: 56:31:11
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN MER 1765301 3128401 0 0 0 16:20:54 LAN Down 0 0 0 0 0 00:00:00 WLAN (2.4 GHz) Up 927215 61492 0 0 0 26:51:22 WLAN (5 GHz) Up 28799580 12481752 0 2 0 26:51:23
Broadband Link Downstream Upstream Connection Speed 10417 kbps 3783 kbps Line Attenuation D1(53.7 dB) , D2(54.2 dB) , D3(65.0 dB) U0(33.7 dB) , U1(53.9 dB) , U2(0.0 dB) Noise Margin 5.6 dB 6.3 dB
Poll Interval:
Seconds (at least 3s):
@jessrabbit3
Yes, definately a fault somewhere . Your hub will show more info.
When was your line activated
jessrabbit3
The 19th of September.
@jessrabbit3
The line can be unstable for the first 10-14 days. Have you been resetting the hub? Is the router plugged into tn main mastersocket. It may improve a bit but not to 55Mbps. If still below 55Mbps call sky
jessrabbit3
Yeah I've tried everything I can think of, using different microfilter etc, I'm aware the speed can fluctuate in first few weeks of line activation but 1/5th the guaranteed minimum speed seems excessive :[
@jessrabbit3
Unfortunately sky only accept a line fault after 10-14 days even if its obvious its not going to make it.
However
Those techy figures are to close together for your guarantee which does make it look external
jessrabbit3
@jessrabbit3
I know .  But get back on this post so we can escalate it to sky after the 14th day👍
jessrabbit3
Anyone know something I can try that I might not have yet?
@jessrabbit3
Unlikely anything you can do. If you've moved house and the line was like this then its likely to be a problem with the copper cabling, possibly even internally.
I am NOT a Sky Employee
