3
This discussion topic has been answered Discussion topic: Garden via Ethernet but how to get wifi
This message was authored by: JoMC0
We have an Ethernet cable running from the sky router to an outside building and have a cat 6 socket  all plugged in and working to which we then have an Ethernet cable going to a windows laptop.  We have a spare Ethernet cat 6 socket but would like to get WiFi up and running to connect mobile phone or iPad to in the garden building and or have a WiFi signal in the garden.
can I use a sky max pod and use an Ethernet cable from the cat 6 socket  to that and then that will give me WiFi ?  Or
Avatar for JoMC0
This message was authored by: JoMC0 Answer
Re: Garden via Ethernet but how to get wifi
Hi
yes i have two Ethernet cables running back to the router..
super I have a spare max pod so will connect and see if that works.
thank you
@JoMC0
Technically that would work, but Sky won't supply a Max pod for that purpose because external buildings are specifically excluded from the terms of the Enhanced Wall to Wall WiFi Guarantee.
@JoMC0 Unless you have two cables running to your Ethernet Socket bsck to the Sky Router then that second one will have NO connection. One cable one connection unless you install a small switch on the system.
Avatar for JoMC0
Hi
thank you
